Kingston A400 Slow Write Speed
5 minutes ago, Boomwebsearch said:
Especially on a budget low-capacity SSD, I can't expect that it would last for 5 years. Not having DRAM cache puts more strain on the flash memory cells lowering their lifespan and the lower capacity models typically have much lower longevity than their higher-capacity counterparts. Just make sure to have a backup of your data and you can safely use the drive until it fails (if you are still within the return-window then I would recommend returning the drive). If the manufacturer has some drive testing software then I would try it out (https://www.kingston.com/us/support/technical/ssdmanager).
GUYS OMG I FIXED THE PROBLEM.
I WAS DISABLED WRITE CACHE.
I RE-ENABLED IT.
AND MY PROBLEM FIXED
LOOK AT THIS BEAUTIFUL SPEED.
https://forums.tomshardware.com/threads/kingston-ssd-low-write-speed.3621651/#post-21834375
10 minutes ago, Not Wills said:I've used and abused my drive with many writes and reads, Its 87% good in 1.5years so, if you take care of the drive and dont install and reinstall things, its should last.
