Will NAS HDD be ok for inside PC?
Go to solution Solved by SupaKomputa,
10 minutes ago, Olly456 said:
Ok thanks, I’m new to building PCs. What are the differences in firmware? What exactly does that mean?
i will be optimized for certain applications in nas enviroment.
elsewhere it will be the same as any hdd.
So I have just found out that the HDD I’ve ordered is a NAS, I have looked into it and found that they are meant for external servers. But have also seen many people use them internally. Will it be ok?
It will work. Its not ideal since NAS drives tend to have NAS optimised firmwares but it shouldn't cause you any issues.
Main Rig:-
Server:-
It means the drives have tweaks done in firmware to tailor them for possibly running 24/7 for their entire lives. NAS Drives also tend to be tailored towards RAID since its very likely a NAS drive will end up in a RAID config.
Main Rig:-
Server:-
Ok, awesome. Thanks!
Ah right, ok! Thanks
