Heya all. Hope yall are keeping safe. I recently decided to give my cpu and graphics more voltage in XTU on my laptop and I noticed when I ran a stress test it shows my laptop is power throttling. Is this something I should be worried about? Also would there be any benefit if I put the cpu volatge back to normal and left the graphics voltage higher? My laptop has an Intel Core i5 7200u with integrated graphics
https://linustechtips.com/topic/1213764-power-throttling/
It wouldn't really surprise me that a laptop would throttle itself (either because of power constraints or thermal constraints). You shouldn't be worried about it. I will recommend, though that you just set i back to stock if you arent getting performance boost out of it.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/1213764-power-throttling/#findComment-13752971
Your laptop isn't designed to supply voltages above Intel's specifications. and why are you increasing the voltage anyways ? You can't overclock in any way, so you are wasting energy and releasing more heat for no real benefit. Reset your voltage overrides.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/1213764-power-throttling/#findComment-13752978
How about the graphics voltage though?
https://linustechtips.com/topic/1213764-power-throttling/#findComment-13753043
There is no benefit of increasing it. Your laptop's BIOS doesn't allow it anyways that's why you see "Power Throttling" in XTU. Your frequencies won't change.
https://linustechtips.com/topic/1213764-power-throttling/#findComment-13753064
