Hello!
I am facing a no post issue with my PC. The MB error code sequence cycle includes 00 15 30 4C with a second long halt on 4C. Any thoughts around debugging would be highly appreciated.
My config:
ASROCK Z370 TAICHI Motherboard (Intel Socket 1151/8th Generation Core Series CPU/Max 64GB DDR4-4333MHz Memory)
Intel® Core™ i7-8700K
RAM CORSAIR VENGEANCE® LED 32GB (2 X 16GB) DDR4 DRAM 3200MHZ C16 MEMORY KIT
GRAPHICS CARD ZOTAC GEFORCE® GTX 1080 TI AMP EXTREME 11GB GDDR5X
SAMSUNG 960 EVO 250GB M.2 NVMe Internal Ssd (MZ-V6E250BW)
CORSAIR MID TOWER CABINET (ATX) - 570X RGB WITH TEMPERED GLASS SIDE PANEL
CORSAIR SMPS TX750M - 750 WATT 80 PLUS GOLD CERTIFICATION SEMI MODULAR PSU WITH ACTIVE PFC
COOLER MASTER MASTERLIQUID ML240L RGB Cpu Liquid Cooler
KEYBOARD + MOUSE COOLER MASTER MASTERKEYS LITE L RGB COMBO
HDD WD BLUE 4TB x 2
Thanks in advance!
Vaibhav
Well following the manual tells me that it could have something to do with either your CPU or RAM.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
from what i can dig out this is that it means:
00: check if cpu is seated properly and then clear cmos
15: memory error. reinstall cpu and memory then clear cmos
30: memory error. reinstall cpu and memory then clear cmos
4C: i dont know xd
what to do: reseat everything, make sure everything is plugged in properly, try using only one stick(try both),
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
4C: i dont know xd
Thanks for a quick revert guys!
My PC was working fine for more than a year and this happened suddenly. Can a CPU move by itself or could I have a dead CPU on my hands? :(
try reseating your cpu. if that doesnt work, try again and again. after like 3 times than your cpu is probably dead
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Hey guys! Thanks again for your response from the other day!
I was able to debug my PC and realized that all the components except for a couple of RAM slots are working fine. I have now installed the RAM sticks in slots A1 A2 since B1 B2 are triggering the error codes I mentioned previously. My question is: is it possible for two slots to fail like this or do they just need some thorough cleaning? I am afraid I can't get it RMAed since we are still in a lockdown due to COVID.
Any thoughts you could share would be highly appreciated.
