What cable do I need
Go to solution Solved by Genesispogi,
6+2pin&6pin or 2x6pin works fine in my sapphire nitro+ rx580...
eight pin and six pin
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750492
11 minutes ago, emosun said:
whats the make and model power supply , also the rest of the system specs
might as well say everything if you havent built pcs before so we can see if it's all ok
I will but my psu doesn’t have that cable what do I do now???
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750537
16 minutes ago, Light-Yagami said:
1x 8pin power cable and 1x 6pin power cable
OR replace 8pin power cable with 2+6pin power cable, sometimes they come split for better compatibility
My psu doesn’t have those wires or cables what do I do will I have to buy a new psu
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750557
5 minutes ago, Leemburns said:
My psu doesn’t have those cables what will I do now
Buy another one that does.
F@H
GPD Win 2
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750580
@Leemburns
1st one: Motherboard power
2nd one: CPU power
the rest: IO devides (HDD, SSD, USB)
You DO NOT have cables for an external GPU
Your PSU is severally outdated and probably underpowered, get a new one. To drive a 970 you don't need more than 400W of PSU.
But I would get a 550W PSU and keep it once you upgrade your system.
I hope this helps
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750596
3 minutes ago, Light-Yagami said:
@Leemburns
2nd one: CPU power
I hope this helps
So this does mean I have to get a new power supply and if I don’t I can’t hook my gpu up?
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750611
Just now, Leemburns said:
Aw no okay thanks
Aw no okay thanks
Affirmative!
Could u suggest a power supply for me as I’m reallY confused now and it kind off has to be cheap as I blew my money on this and it won’t even work now please it’d mean a lot
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750626
https://www.tomshardware.com/reviews/best-psus,4229.html
Choose one from this list. I vouch that they run elaborate tests to determine which PSU are good and which aren't.
Shoot a like my way as well, or mark one of my replies as "mark as solved" so people know no more commenting is needed
https://linustechtips.com/topic/1213419-what-cable-do-i-need/#findComment-13750639
