The H500 is a great case. I'm speaking from my own experience ater buying it becaus of the great review from GamersNexus. Just be sure to buy the mesh-front variant and not the one with the acrylic front, as the acrylic blocks 90% of the airflow.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1212175-better-case-choice/#findComment-13740931
