Wanted to know if a corsair icue 220t airflow case would work for my pc parts if there would be any clearance issues my pc parts so far
Intel i9-9900K
Gigabyte Z390 Aorus pro
G skill ripjaws v32 gb ddr4-3600
Adata xpg sx6000 pro 1tb m.2-2280
Zotac geforce rtx 2080 ti amp maxx
Corsair icue h150i rgb pro xt
Corsair rm 750w 80+ gold
https://linustechtips.com/topic/1211462-beginner-build/
Intel i9-9900K
Your GPU is 298mm long and the case supports up to 300mm. This is very tight. Depending on how Corsair measure the card length, you may have to remove a front intake fan for it to fit
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1211462-beginner-build/#findComment-13735350
25 minutes ago, NZgamer said:
It will work
It's very easy to find if everything will fit, just go onto all of the specs pages and check the dimensions. I doubt you need to make a forum post so we can check it for you
https://www.corsair.com/eu/en/Categories/Products/Cases/Mid-Tower-ATX-Cases/iCUE-220T-RGB-Airflow-Tempered-Glass-Mid-Tower-Smart-Case/p/CC-9011173-WW
https://www.zotac.com/au/product/graphics_card/zotac-gaming-geforce-rtx-2080-ti-amp-maxx#spec
(I don't want to sound rude or anything just want you to know it's extremely easy to find this out for yourself)
Sorry didnt know genuinely the first pc i build so dont really know anything
https://linustechtips.com/topic/1211462-beginner-build/#findComment-13735413
