i was just casually watching youtube, and then i saw that an app was using my microphone.  i went to see what it was, and it was svchost.exe.  I know thats not a virus, but i never experienced this kind of this.  any suggestions to what i should do?  i dont really know where to say this, so sorry if this is the wrong place.
https://linustechtips.com/topic/1211137-svchostexe-using-mic/
run your antivirus. also in task manager, check the file location.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1211137-svchostexe-using-mic/#findComment-13732742
have you run an anti virus check? also check in with microsoft. go to support and ask if there is a problem.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1211137-svchostexe-using-mic/#findComment-13732750
svchost.exe is a host-process from Windows that is used to run all kinds of services. So if you have a background service that uses the microphone, that would explain why it seems "svchost.exe" is using it (the process hosted by the host-process is using it).
If you right click the "svchost.exe" entry in task manager, there should be a "go to service" that should take you to the actual service that is being hosted.
https://linustechtips.com/topic/1211137-svchostexe-using-mic/#findComment-13732914
