My budget for now is 600 USD
Country-USA
* Here's things to know with what I need help with. This RIG is going to be a build i'm going to be Upgrading part by part
Its a Working Progress so I want to start somewhere good.*
In the Future i'm hoping to Game at 1440p and Edit Recorded Vid's
For this build, I want to start by making this able to game at 1080p even with AAA Games , and Light Edit some Recorded game play.
Edited by SansVarnic
Moderator Reasons
https://linustechtips.com/topic/1211124-please-help-me-yall/
8 minutes ago, JeffePeachMan said:
It’s a complete new build
Do you think you will want to upgrade to 4th gen Ryzen, or would something like the 3600 be sufficient?
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732740
14 minutes ago, JeffePeachMan said:
Starting at 3600 would be ideal because it’s a working progress
Here's my suggestion
Thing to note & my reasoning:
-For motherboard I picked the tomohawk because it should support most 4th gen Ryzen, and all of 3rd gen so you should not need to upgrade it. Alternatively you could get a slightly cheaper ~$90 board but it may not have as good support for higher end parts. Or you could get something like the B550 mortar which will cost you $160 but have the best performing VRM and best support for 4th gen (and you get pcie 4.0)
-Unfortunately I could not fit in the 3600 at your price point, so I would suggest either upgrading to a higher end 3rd gen part if they decrease in price, or upgrade to 4th gen ryzen.
-Rx570 is a filler card and will do entry level 1080p. It should be the first thing you upgrade if your focused on gaming. Try and buy one used to save a bit.
-I spent more on psu, case, motherboard and memory so they will not need to be upgraded in the future
-You can add storage later but 240GB will do your OS and a couple of games
I know this is a lot of info and it's just my opinion on what I would do.
Hope it helps :)
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732779
Do keyboard, mouse, monitor need to fit in the $600 budget?
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732790
-Unfortunately I could not fit in the 3600 at your price point, so I would suggest either upgrading to a higher end 3rd gen part of they decrease in price, or upgrade to 4th gen ryzen.
Hope it helps :)
What do you think he'll need to upgrade step by step after hes done his GPU Upgrade to something like a 1660 ti. Would he have to upgrade his CPU? or Memory? and If so which ones would you suggest? He does say he plans on recording and edit videos!!   Your information is really good by the way!
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732793
Memory should be good for a while so long as 4th gen Ryzen doesn't benefit from crazy high speeds, and unless he needs 32gb. CPU, probably either upgrade to the 3600/3700X (or even new XT parts) but probably best to wait and see what zen 3 gives us and then decide. As far as GPU upgrade, again I would try and wait to see what RDNA2 and Ampere have to offer
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732804
im kind of unfamiliar with RDNA2 and Ampere but tell what do they offer that has importance to wait? for a gpu upgrade?
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732828
Well it's all speculation and leaks at this point. Considering we are so late in the cycle though, anyone thinking of buying new, especially high end stuff, is best to wait just so they don't pay for something now and then find they could have gotten something better for less in a few months. Also with AMD powering the new consoles Radeon are expected to make big gains this year (hopefully)
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1211124-please-help-me-yall/#findComment-13732997
