PSU pcie cable and extension question
nkg123
I have an RTX 2070 SUPER which requires a 6 pin pcie and 8 pin pcie connection. I'm using cable extensions and there are two 6+2 pcie extensions. Can I plug in the 6 pin pcie cable from my psu into the 6+2 pin extension and then plug in the 6 of the 6+2 extension into my gpu?
For the most part should be fine
Phone: Pixel 3a (Purple-ish).
Build Log:
