Should I Start Using Linux ?
Solved by Deano727,
You don't sound rude
If I was you, I'd start out by trying to partition your drive (you only need like 20-40GB for the partition if you're not really going to install programs or save a bunch of files (you can make it whatever size you want) and installing Linux on there. this way, you still have access to Windows like you're used to but you can install and run Linux with no real down side and slowly get used to it until you're confident enough to switch to linux entirely. Also, you can keep installing different distros of Linux until you find one you like, just go for it!
