3700x cooling
Solved by 00RaZoR11,
On 6/17/2020 at 10:47 PM, mach6 said:
- Buy a third party cpu cooler
- Buy two 140mm fans
If you don't wanna spend much, an arctic freezer 34 would be a good idea. You can either add 2x 140mm arctic fans in the front (f14 or p14), or I have a feeling it would be fine if you had 3x 120mm intakes, which would require only 1 more 120mm fan. Again arctic, either f12 or p12.
The 2x 140mm intakes & 2x 120mm exhausts would be flawless with anything at least as big as the freezer 34 (non esport). I think any 4 heatpipe cooler more expensive or smaller than the freezer 34 is a waste of money.
Other coolers I'd consider (quickly browsing through my favorite store): noctua nh d15, nf u12a; thermalright true spirit 140 power, silver arrow ibe, archon ibe; be quiet dark rock 4 (pro)
