I got 2 m.2 ssds one nvme one sata, on my motherboard I got one nvme m.2 slot and one sata only slot, but by some reason my sata m.2 ssd only works in a nvme slot, while nvme one works in both.
So if I want to use both I have to put them in reverse which limits my nvme ssd speed.
This is really bizzare to me, any solutions?
Specs:
X370 taichi, 2700x, nvme ssd - Samsung 970 pro, sata ssd - wd green.
https://linustechtips.com/topic/1210764-weird-m2-problem/
Does the BIOS see both drives, in their respective slots...?
... or is this the BIOS you're talking about...?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729619
1 minute ago, or3xtl said:
Bios only detects the wd green ssd in the first slot
... the Samsung doesn't get seen in either slot?
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729649
So; Samsung in slot one & WD in slot 2 gives one drive seen...?
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729662
Sounds like the second slot is disabled, when the first slot is occupied.
Are there ANY other S-ATA devices attached to the other ports?
Sometimes you'll get lanes shared between S-ATA & m.2 ports...
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729685
Quote from your user manual:
Check the connector on the drives to see if they're "keyed" correctly.
EDIT:
https://en.wikipedia.org/wiki/M.2
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729701
Found this: https://www.asrock.com/mb/AMD/X370 Taichi/index.asp#Storage
Could be that the WD drive may not be supported by slot 2.
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729748
It's not on the list, but Samsung is also not on the list, so I'm not sure if that's the problem, if it's just incompatible that's a bummer.
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729788
That would be my 'suspicion', but I'm not saying that it's 100% right.
WHY NOT...?!
https://linustechtips.com/topic/1210764-weird-m2-problem/#findComment-13729801
