With wires and preferably the correct connector on the end to connect to your MB.
Something along the lines of the below item and solder the wires to the RGB strip. If you really want to Yolo it, you could just attach wires to it and connect them to the individual pins on the MB header (with something like electrical tape may work just fine, but would be a pain to wrap around and undo if you needed to), but I wouldn't recommend doing that personally, and also make sure they don't touch each other in any unshielded part of the wire...
https://www.arrowelectricals.co.uk/interior-lighting-c86/led-strip-lighting-c13/connectors-c278/arrow-12v-10mm-rgb-led-strip-single-ended-connector-130mm-p1471/
https://linustechtips.com/topic/1210480-rgb-problem/#findComment-13727769
11 hours ago, GODSLAYER HRIDY said:
I have a RGB strip but no 4 pin header on it. I know it should be connected in a 4 pin slot because it has 12v, r, g and b input copper circles on the strip. How do i connect it to the mobo's 4 pin rgb connector without buying a RGB header for my strip
would be better to use something like this and solder them to the strip. there are many videos on you tube how to solder to a strip..
https://linustechtips.com/topic/1210480-rgb-problem/#findComment-13729014
