Hey guys, I made a list of parts and I just want to know if you all believe these are compatible. I'm 99% sure they are, but I would really appreciate some double checking!
MSI Graphics Card RX 570 8GB - $140 - https://www.newegg.com/msi-radeon-rx-570-rx-570-8gt-oc/p/N82E16814137521?item=N82E16814137521&nm_mc=knc-googleadwords&cm_mmc=knc-googleadwords-_-video cards - amd%2Fati-_-msi-_-14137521&source=region
OR
RX 560 4GB - $100 - https://www.newegg.com/xfx-radeon-rx-560-rx-560d4sfg5/p/N82E16814150816?item=9SIAD2C8AM5632&nm_mc=knc-googleadwords&cm_mmc=knc-googleadwords-_-video cards - amd%2Fati-_-xfx-_-9SIAD2C8AM5632&source=region
I3 7100 KL Dual core - $125 - https://www.newegg.com/core-i3-7th-gen-intel-core-i3-7100/p/N82E16819117734?item=9SIA12KAGB9987&nm_mc=knc-googleadwords&cm_mmc=knc-googleadwords-_-processors - desktops-_-intel-_-9SIA12KAGB9987&source=region
ASRock Motherboard Z270 Gaming K4 - $140 - https://www.amazon.com/dp/B01MT5WRBJ?tag=pcpapi-20&linkCode=ogi&th=1&psc=1
2 x 8GB DDR4 2400MHZ "Gaming" Ram - $65 - https://www.amazon.com/dp/B017NW5NZY/ref=twister_B07W36NHV8?_encoding=UTF8&psc=1
OR
2 x 4GB DDR4 2400MHZ "Gaming" ram - $50 - https://www.amazon.com/Corsair-Vengeance-2400MHz-Desktop-Memory/dp/B019HVND88/ref=sr_1_3?dchild=1&keywords=8gb%2Bddr4%2B2400mhz%2Bram&qid=1592366235&sr=8-3&th=1
(OPTIONAL) 120 GB SSD SATA III (For windows, maybe a few games too, idk) - $25 - https://www.amazon.com/Inland-Professional-120GB-Internal-Solid/dp/B076XMH2JT/ref=sr_1_2_sspa?dchild=1&keywords=120gb+ssd+sata+3&qid=1592363233&s=electronics&sr=1-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFVNVlTODBDWjJYS0smZW5jcnlwdGVkSWQ9QTA0ODYyMzEzNURRNjdCMTNDTFIyJmVuY3J5cHRlZEFkSWQ9QTEwMjI4MjgyM0tGN1JET0JaNEZaJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Hard drive 2tb 7200 RPM 3.5 inch Seagate barracuda - $55 - https://www.amazon.com/Seagate-BarraCuda-Internal-Drive-3-5-Inch/dp/B07H2RR55Q/ref=sr_1_21?dchild=1&keywords=1tb+sata+iii+hard+drive&qid=1592363434&s=electronics&sr=1-21
ATX PSU 500W - $50 - https://www.google.com/shopping/product/7715966952317604874?q=thermaltake+500w+psu&prds=epd:15730199432026797875,prmr:3,tpim:CPDUquXst7Ts7gEQwIWJ69_ayYoTGLD8uRUiA1VTRCjg39n3BTD2utg7,pdprs:5&utm_medium=tu_cu&utm_content=eid-lsjeuxoeqt&utm_campaign=125181302&gclid=CjwKCAjw26H3BRB2EiwAy32zhQEWTue4Z73guzfOmuk75zcDTmRHqJF5nXXj3OBs1ampJUefOfYI1hoCX80QAvD_BwE
Case - $55 - https://www.newegg.com/white-fractal-design-focus-g-series-atx-mid-tower/p/N82E16811352067?&quicklink=true
Wifi Card because I'm not confident the motherboard has any onboard wifi. Here is a m.2 and PCIE wifi card - https://www.amazon.com/FebSmart-Adapters-PCIe-Cards-PCIe-FS-N600-Basic/dp/B071NZ6DL9/ref=sr_1_6?crid=S1D5NQYC16FW&dchild=1&keywords=pcie+wifi+card&qid=1592365168&s=electronics&sprefix=pci+%2Celectronics%2C181&sr=1-6
$20 - https://www.amazon.com/UFON-MU-MIMO-Wirelss-Bluetooth-Support/dp/B07SH6GV5S/ref=sr_1_1_sspa?dchild=1&keywords=m.2+wifi+card&qid=1592365479&s=electronics&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyMURMUk0zSjY4TlhRJmVuY3J5cHRlZElkPUEwMDA2NTU4M05LSzVGSlhKWUgwVCZlbmNyeXB0ZWRBZElkPUEwMzg2MTk2V0lOUVZZVEFUMVo5JndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
windows 10 is around 20 bucks on a third party websites
https://linustechtips.com/topic/1210467-pc-build-plan/
1 minute ago, BlueScope819 said:
No, you don't understand. Put it in PCpartpicker and send me the URL to it, it does the comparability checking for me in addition to formatting it nicely when you insert it into the fourm. For example:
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor $274.49 @ Amazon
Motherboard Asus ROG Strix B450-I Gaming Mini ITX AM4 Motherboard $402.23 @ Amazon
Memory G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory $179.99 @ Newegg
Storage Samsung 860 Evo 2 TB 2.5" Solid State Drive $299.99 @ Amazon
Power Supply EVGA SuperNOVA GM 650 W 80+ Gold Certified Fully Modular SFX Power Supply $199.99 @ Amazon
Custom DA2 $200.00
Custom GPU backplate $43.99
Custom Assorted fittings $100.00
Custom Hardline bending kit $20.00
Custom CPU water block $109.99
Custom GPU block $164.99
Custom Pump / res $76.99
  Prices include shipping, taxes, rebates, and discounts
  Total $2072.65
  Generated by PCPartPicker 2020-06-17 00:09 EDT-0400
Ahhh, big noted.
https://linustechtips.com/topic/1210467-pc-build-plan/#findComment-13726991
10 minutes ago, TheCjweej said:
*snip*
Are you only looking for compatibility check or opinions on the list? Because assuming you are buying all of this now, you could get better.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1210467-pc-build-plan/#findComment-13727006
-= Thread Cleaned =-
Lets make this easy, derailing the topic is not acceptable.
If you have a non-related question ... Make a New Topic.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1210467-pc-build-plan/#findComment-13727357
