Science problem.. :/
Found this hope it helps explain easier...
Calculate Acceleration from a Force
  1. 670px-Calculate-Acceleration-Step-4-Vers
    Find the mass and the force. Acceleration happens when a force acts on an object, causing it to change speeds towards the direction the force is pushing or pulling it. To know what the acceleration is, in a vacuum at least, you need to know the following
    • The strength of the force (F), measured in Newtons. One Newton will accelerate one kilogram by one meter per second2.
  2. The mass (m) of the object, measured in kilograms.
Apply the formula: F = ma, force equals mass times acceleration. You can change this formula around to solve for acceleration by dividing both sides by the mass, so: a = F/m. To find the acceleration, simply divide the force by the mass of the object being accelerated.
Example: a 10 Newton force acts uniformly on a mass of 2 kilograms. Divide 10 Newtons by 2 kg to get 5 meters/second2.
got to love Asus components
https://linustechtips.com/topic/121040-science-problem/page/2/#findComment-1614455
Coriolis effect anyone :lol:
God I hate the Coriolis effect. Very few real-world systems even take the Coriolis effect into account when designing controllers, yet I still have to do it in my Robot Controls class.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/121040-science-problem/page/2/#findComment-1614507
First year of high school lel ^^ im 16 .__.
Don't get bogged down in the "I know nothing about aeroplanes " mind set, reduce it to what you know. Ignore lift vectors, tire friction, skin drag etc etc etc
An object(of such and such a mass) undergoes a force(of such and such a size) what is its acceleration?
'They' even tell you what equation to use F=MA (Force =mass X acceleration) you are given mass and force so only acceleration to find
At 16 you should be more than able to manipulate very simple equations.
Treat an equals sign like a balance scale so whatever you do to one side you must do to the other
so F=MA becomes, after dividing both sides by mass
∴ F/M =M/MA
∴ F/M=1xA
∴ F/M =A or A=F/M
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/121040-science-problem/page/2/#findComment-1615080
∴ F/M =M/MA
∴ F/M=1xA
∴ F/M =A or A=F/M
Nothing new....
https://linustechtips.com/topic/121040-science-problem/page/2/#findComment-1616602
Nothing new....
Didn't say any of it was.
EDIT :-
For some reason I thought it was Cyrus that asked the original question when it was Vopos.
https://linustechtips.com/topic/121040-science-problem/page/2/#findComment-1616968
