Is there a way to manage power consumption on a DIY Nas say with an i3 processor in like freenas? Or would it be better to buy a prebuilt NAS to save on power since they run lower at idle? If I was using it as a Plex server should I just use a smart plug to have it run not 24/7?
https://linustechtips.com/topic/1210372-power-consumption-on-nas/
it will auto downclock and you can have it spin down HDD after an hour or something. the thing is a prebuilt nas has a lot less power than a custom built one and you don't have the flexibility.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
So the power consumption difference does not really matter when it comes down to it?
the custom built will be higher but how much matters on what parts
