Hi LTT Forums, weird issue here hopefully someone can shed some light on.
The CPU fan on my system is kicking up a warning when starting the computer (red writing, before the BIOS load screen even)
I checked the speed in HWMonitor and it's running fine, but the issue seems to relate to the RGB on the cooler.
The Cooler is the AMD Wraith Spire RGB, for some reason, it will only display Red and Green LED colours now, even when you choose other colours.
One caveat is that the motherboard is a MSI B350M Mortar so the cooler never displayed full RGB, it can only do single colour via the MSI Gaming App.
I have it set to CPU temp usually, so it displays red when hot and blue when cool.
Thanks in advance!
https://linustechtips.com/topic/1210294-cpu-fan-error-rgb-affected-only/
