Hey everyone,
I am getting this error after plugging in my USB condenser microphone (MXL Tempo). It is a driverless microphone and it keeps disconnecting and reconnecting, which is playing that windows sound that indicates there is a new USB device plugged in.
I don't know what will fix this as I have redownloaded all drivers, uninstalled, disabled, re enabled, changed power settings, pretty much everything you can think of. Does anyone have any idea about what can truly fix this issue?
Thank you,
Sam
Intel 10700k
Gigabyte Auros AC Pro Wifi (Z490)
Ballistix 16GB ram
https://linustechtips.com/topic/1210253-usb-device-not-recognized/
Seems like the microphone cable is going bad or damaged, i suggest you get a replacement.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
@Void Master I actually had a spare, it did the same error with that and a different microphone as well.
I never had this problem until I de dusted my computer. Do you think that could have created an error?
It shouldn't do that.
Can you reinstall the motherboard's chipset and audio drivers ?
Just now, TheSuperSawm said:
Does this provide any additional help?
it's basically the same as the picture you provided earlier.
1 minute ago, TheSuperSawm said:
@Void Master hahahah I kinda figured. No dice on the reinstall of the audio drivers :/
I honestly have no idea what else could be done.
What about the chipset drivers ? those are responsible for USB.
reinstall them.
36 minutes ago, TheSuperSawm said:
@Void Master Not sure if this helps narrow down the problem:
Can u uninstall those 2 specific drivers ?
try using the USB 2.0 ports on the motherboard.
@Void Master Thank you for all of your help today. the issue was solved by converting everything over to USB 2.0 except for the microphone. I plugged that into the USB 3.2 Gen 2 and that worked for whatever reason.
Great to know it worked.
Hello LTT community and @Void Master
I wanted to follow up and let you know the problem wasn't fixed by switching the USB ports. I should have done something like this sooner, but I was too infuriated to think straight.
The problem is in this picture:0?ui=2&ik=b5e5cb3bfd&attid=0.1&permmsgid=msg-a:r-2233236537496784849&th=172c9354f94eefd5&view=fimg&sz=s0-l75-ft&attbid=ANGjdJ8oANluAEgEPTKz-ZmhnVMR-bQEAv6aGr9JRc7YKShFuZY15fBIG0tEFAXF0InM9rFCFDRLFUyLbDrbAusu7eRvCu3IN2kWEcFz5gqDhIUXz_C3ReruHAuujL4&disp=emb&realattid=172c935106cbdd314401
It looks awfully nice at first glance, but the problem is actually the light that is surrounding my camera.
The light is powered off of USB and I stupidly thought the problem was my microphone the whole time......The reason the computer couldn't figure our what drivers it was supposed to use is because the light had no drivers!
Anyways, thank you again @Void Master for all of your help, I figured I would follow up and let you know that the problem is 100% confirmed fixed :)
Now, maybe I can try to work on that DAC of mine and get that sorted next :P
See ya,
Sam
See ya,
Sam
oof that's weird.
There are some stuff in PCs that you only learn through experience.
But beware sometimes these issues are sometimes caused due to weak 5v supply from the PSU.
Great to know it worked :D
1 minute ago, Void Master said:
oof that's weird.
Thanks for the tip. I have a 1000w EVGA supernova G2 (I think) so I thought that it would be beefy enough to handle, but maybe at some point I'll need to upgrade. Also I'm moving soon so don't mind the cord mess hahaha
That PSU is more than enough.
It might be malfunctioning or degrading though.
Can u RMA it or try another PSU ?
In case the problem happens again, check your PSU.
