I'm trying to talk my friend into building a media/gaming PC rather than buying the next gen consoles that will be launching soon.  Our budget is $575 firm.
It needs to be as quiet as possible for watching movies and he will be playing games like call of duty, skyrim, and battlefield.  I know we won't be breaking any FPS records here but if we could get a playable system that'd be great.
This is how I've speced it so far.
CPU: Intel i3 3220
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116775
MOBO: Asrock h61m/u3s3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157236
GPU: MSi 650 ti
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127725
RAM: Patriot G2 1333mhz 2x4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220557
Storage: WD Blue 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Power supply: Corsair CX430M (already on hand, left over from other project)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139049
Case: Fractal Core 1000
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352009
Optical drive: LG black SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136252
Can you think of anything that could be improved silence or performance wise?
I know the stock cooler on my i3 2120 is pretty quiet but that chip runs very cold.  I'd love to throw a hyper 212 on there but I don't think the case is wide enough.
Do you see any compatability issues?
Will this power supply be enough?
Thanks in advance for any insight.
https://linustechtips.com/topic/12098-500-console-replacement/
I had to accept my stupid warning for you so you better take my advice :P Get the AMD 6300/6350, will be MUCH better for gaming than i3. Also I would get rid of the optical drive; you never need one anymore. Then I would get the Asus 2gb 7770, the 7770 will run circles around the 650ti.
Edit* yes that psu will be enough
Edit* I would also get a 8gb kit of corsair vengeance low profile Pretty much the same price. I would also get the cx500 (it isn't semi modular but in that case cable management isn't going to be really possible) which is the same price. And for the Motherboard for the AMD cpu I would get the  msi 970a gd46.
Edit* And for a case to fit a normal ATX board I would go with the http://www.newegg.com/Product/Product.aspx?Item=N82E16811146102
Edit* The parts I listed will be a way faster/better gaming rig with overclocking potential and looks better :)
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129128
After calculating the pricing of everything, I came across a 650 Ti Boost 2GB from Gigabyte. You can find that here. Sadly, with the current setup, it'd be too expensive. I removed the optical drive, and got 576.93 dollars, which is still slightly over. I also found a 2GB 7790 from Gigabyte, which can also be found here. It's the same price as the 650 Ti Boost.
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129159
I like it but this will put me way over budget.  That case might be a winner though, it looks like it will have enough room for a decent heatsink.
Thanks
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129160
This is a build I created. This motherboard might require a bios update in order to support ivy bridge. I went for an i5 because this will help avoid bottlenecking if you plan to upgrade the gpu. Chose a Gigabyte board because I think they are better quality than the Asrock board:
PCPartPicker part list: http://pcpartpicker.com/p/U7d0
Price breakdown by merchant: http://pcpartpicker.com/p/U7d0/by_merchant/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor  ($220.98 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Newegg)
Motherboard: Gigabyte GA-H61MA-D3V Micro ATX  LGA1155 Motherboard  ($54.99 @ Newegg)
Memory: Patriot Gamer 2 Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg)
Video Card: MSI GeForce GTX 650 Ti 1GB Video Card  ($94.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 ATX Mid Tower Case  ($57.98 @ Newegg)
Power Supply: Corsair CX 430W 80 PLUS Bronze Certified ATX12V Power Supply  ($39.99 @ Newegg)
Total: $558.91
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-04-30 19:08 EDT-0400)
EDIT: Forgot to add the blu ray drive, so add $50, but it is over your budget... :(
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129167
Thanks
Nope it will come to to 590$ but the GPU has a 15$ mail in rebate which will bring you under!
Edit* if you get the fx 4300 instead of the 6350 it will bring you under and with the mail in rebate it will bring you way under and will still be a better gaming cpu than the i3 in my opinion
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129172
I'd go for this case.  It's a more expensive case but the free optical drive promo makes it basically the same price as the other two you were considering: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
I can't recommend the CX430 power supply, they are not really very high quality and have known issues with coil whine.  Think about exchanging it with this: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151072
Save a little on RAM: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1250228
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129250
I actually already have the power supply on hand so I'm gonna give it a shot.  Thanks anyway though
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129331
Alright.  It may or may not coil whine, but I have heard a lot of stories about it and half the units I've used personally have exhibited it, so yours may be fine.  In any case it's just a potential noise issue, at least the unit isn't dangerous like some other ones can be xD
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129352
yea lol, I've seen some $20 specials from a certain retailer here in the states that were scary.  One got so hot under load the sticker melted and the paint started to bubble.
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-129387
  • 3 weeks later...
GTX 650ti is better than the 7770.  Have you seen any benchmarks between the two?
http://us.hardware.info/reviews/3233/19/nvidia-geforce-gtx-650-ti-review-gigabyte-vs-msi-vs-zotac-geforce-gtx-650-ti-vs-radeon-hd-7770
i3-2120|4gb 1333|GTX 650ti 1gb|Fractal R4|Corsair 430w
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-211892
Total: $558.91
Tax alone would destroy the budget.
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-212521
Here you go: http://gyazo.com/6bbb9ac58d62ccce7f3a9bc6edd3d64c
Should be a bit over $500 after taxes or other fees.
If it's not impossible, replace the 7770 with a 7850. It will be about $600 in all but will be able to play just about everything at high settings.
Edit: I forgot you already had a psu. The 7850 should totally fit in the budget.
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-212573
Here's my take on a setup: http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=22211812
Squeezed the optical drive, 7850 2GB, Phenom 965, Hyper 212+ and other stuff into $525.92 without tax and shipping. Should be under $575 with shipping and tax. Since you said you already have a 430w psu I didn't add a psu in the build. Your 430w psu should be ok for a 7850.
CPU: AMD Phenom II x4 965 BE       ($94.99)
GPU: PowerColor AX7850 2GB      ($184.99)
MB: ASRock 760GM-GS3 AM3        ($39.99)
RAM: Crucial Ballistix Tactical 4GB  ($28.99)
PSU: None                                          ($0.00)
CASE: NZXT Source 210 S210-001  ($34.99)
HDD: Seagate Barracuda 500GB     ($59.99)
COOLER:  CM Hyper 212 Plus         ($31.99)
OPTICAL: LG Black 12x Blu-ray       ($49.99)
Total: $525.92
One thing I would like to say though is that the build I made has little options to upgrade without buying new parts.
https://linustechtips.com/topic/12098-500-console-replacement/#findComment-214274
