Hi,
My name is Greg and I stream with a Dual PC setup.  My current processor the i7 7820xe processor is not cutting it with all of the overlays and multi-source scenes.  Im looking to upgrade but what processor will help with the encoding that Streamlabs OBS does?  Is it more cores? Higher CLock speeds? I want to get the right processor for the job but im not sure what to get.  I would think more cores and a more productivity focused processor would do.  PS I dont want to code in the Nvedec style. I want to go x264.  If anyone can shine some light and give me some suggestions that would be great.
Price is of no matter at all. I stream full time so i want to invest into my setup and my stream does pretty well so price is no object.  I just dont want to buy a 2k processor unless i know its going to solve my problem.  I would like to stay intel but i know the threadripper is pretty good with productivity.  SO ANY info or opinions or knowledge would be great! Thanks in advance!!
https://linustechtips.com/topic/1209786-cpu-upgrade-for-stream-pc-help/
I would recommend a 3900x. They recently got a price drop, and 12c/24t will destroy streaming. If you really wanted to ball out you could go for a 3950x, but I feel like threadripper isn't really necessary.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
