VGA FAIL ( HELP)
Go to solution Solved by mariushm,
Install the video card drivers.
Hi so I’ve just finished building my pc however my gpu is not showing up in the system nor the integrated graphics of the cpu, also everything is on 786p and it says
‘vga failure , download vga drives ‘,
the monitor however is displaying everything as it should.
https://linustechtips.com/topic/1209743-vga-fail-help/
