Hey y'all
Here's my specs first:
  • ASUS ROG Strix B450-F Gaming
  • Cooler Master MasterBox Lite 5
  • Corsair Vengeance LPX (4 x 16 GB)
  • Samsung 970 EVO Plus
  • KFA2 GeForce GTX 1650 Super EX
  • Corsair RM650x
  • AMD Ryzen 7 3700X
I've been tinkering at the BIOS of this build for about 2 weeks now. The CPU i've got down to behave pretty well now. I've been experiencing some trouble when trying to adjust my RAM speed tho. According to CPU-Z as well as Corsair's own webpage, the SPD of it is 2133 MHz at 15-15-15-36 and 1.2 V. That's also what it is running at now.
Now in the ROG's BIOS, in the Ai Tweaker options, i have the option to activate Asus's DOCP, which correctly recognises frequency and latency as well as voltage. I turned this own, tried saving and rebooting and the PC shuts off on its own mulitple times (and its one of those "click" and suddendly no more power shut down), I get no POST on every try and after multiple tries, it turns on without having changed anything according to CPU-Z and task manager. When I go into the BIOS again, the options are still the same, but the memory is running at 2133 MHz.
Anything I'm doing wrong? I've tried manually adjusting the values aswell, same result.
THanks for all of your help
https://linustechtips.com/topic/1209720-problems-adjusting-my-memory-speed/
3 minutes ago, James Fin said:
Asus's DOCP,
It's not from Asus, it's from Intel (XMP) and AMD copied it over (DOCP). The profile XMP and DOCP applies is from the memory kit vendor so whatever you call it, it's not from Asus.
2 DIMM per channel setups (especially with capacity this high) is hard on the board, so not surprised that a premium budget board like this doesnt work with it. Not even a Ryzen problem at this point, Intel platform does the same.
Desktop benching:
Link the RAM you are using?
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Update the bios
Set the soc to 1.1 and dram to 1.35
Clear the cmos
Try that
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
@Jurrunio you're absolutely right, I'm sorry. AMD'S DOCP recognises Corsair's memory profile.
Is there anything I can do about the dual DIMM per channel setup? Is it even worth it, considering that it might make the system unstable? Thanks a lot for your help
You could try manually setting up the timings if you have time (a lot of time, since fully stress testing this much memory takes half a day with only an 8 core CPU), or lower the frequency with the same timings and voltage in the XMP profile (for example stock timings is 16-18-18-38 at 1.35V, you manually enter these into the memory settings and select 2933MHz instead)
Desktop benching:
From what I know Ryzen hates CL15.  And from my experience using 4 sticks - OCing anything past memory controller chips on CPU and mobo are not easy (I am unable too).
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
