no
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1209554-cpu-bottleneck-help/#findComment-13719299
The 1600 (AF 12nm) is the perfect price to performance gaming CPU right now. You'll not be bottlenecked by it for a long time. If you up your pesolution to 1440p or higher in the future chances are you'll be GPU limited either way for the most time.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1209554-cpu-bottleneck-help/#findComment-13719347
yeah im not running 1440 cause i only have 1080 monitor
https://linustechtips.com/topic/1209554-cpu-bottleneck-help/#findComment-13719373
Anyway don't worry about it you have a great combo with your CPU + GPU.
https://linustechtips.com/topic/1209554-cpu-bottleneck-help/#findComment-13719376
ok, thanks you were more helpful than kyles videos and that one guys no
Haha, if you wnat informative Videos go for GamersNexus or Hardware Unboxed. Bitwit and JayzTwoCents are more on the entertaining side and LTT is somewhere in between. 😅
https://linustechtips.com/topic/1209554-cpu-bottleneck-help/#findComment-13719383
yeah everything i know is from ltt so it has to be somewhat educational
https://linustechtips.com/topic/1209554-cpu-bottleneck-help/#findComment-13719387
