Budget (including currency): 600-700$usd
Country: USA
Games, programs or workloads that it will be used for: mostly will use it for Modern Warfare and other Third and First person shooter games. Also would like to do school work on it.
Other details: Im switching over from console and need help finding a good build in my budget. I will also buying a 144hz monitor.
https://linustechtips.com/topic/1209027-need-help-with-build/
Make sure you buy a freesync monitor. My recommendation -
Monitor: MSI Optix G24C4 23.6" 1920x1080 144 Hz Monitor  ($179.99 @ Best Buy)
Also, my recommendations for cheap peripherals-
Keyboard: Redragon K552-R KUMARA Wired Gaming Keyboard  ($38.99 @ Amazon)
Mouse: Corsair Harpoon RGB Wired Optical Mouse  ($15.99 @ Best Buy)
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1209027-need-help-with-build/#findComment-13715033
