12 minutes ago, Linus Drop TIps said:
I have two questions, one do I need the same specific drives (I’m using nvme drives) or just the same amount of storage on the drives, and two what RAID should I use for my drives?
Thanks in advance.
What are you trying to do?
3 minutes ago, Linus Drop TIps said:
I want to experiment with raid, don’t have the money to buy a 2tb PCIE gen4 ssd, and need the storage.
Okay but like RAID 1 isn't really nessiary at all
and RAID 0 is going to risk your data constantly pretty much
You can just set up a simple RAID volume in windows, or do it in your motherboard bios.
The Gen 4 SSDs aren't actually that much better, because they haven't made Gen 4 controllers yet.
Thanks
