Hey guy I'm lovepreet Singh from India.
I'm facing a problem of booting up my pc
I've recently  brought  it my spec are
1. Ryzen 5 3600
2. Gigabyte b450 motherboard
3. Adata 16gb 2400mhz single stick
4. Corsair  vs550 watt power supply
5. Gigabyte gtx 1660 super dual fan
My problem is, everything time I've  restart my pc it show a bar code error I dont what's helping due to this error message I have to install new windows  again and again but this is not the end of problem. After this bar code error I can not be able to install window. FB_IMG_1591923754387.jpg.5fbf8d57b6ceb8783c1d25d664861ab0.jpgFB_IMG_1591923531366.thumb.jpg.4c383295b44dbbdcec675b0f1edc0929.jpgFB_IMG_1591923523706.thumb.jpg.353d5b4448e2c024e92c165af75fc134.jpg
https://linustechtips.com/topic/1208076-startup-problems/
4 minutes ago, Zmax said:
Have you check the Bios number. Depending on the Bios you Ryzen 5  3600 may be the cause of the blue screen
https://www.gigabyte.com/Motherboard/B450-AORUS-M-rev-10/support#support-dl-bios
Yeah I have its f50. should I update it again ??
Because I didn't  updated it came in by default and it's the lastest one
https://linustechtips.com/topic/1208076-startup-problems/#findComment-13707606
