Hello! i need some help about finding the right SSD for my gaming laptop its a
Specs: Alienware M14x
Intel - Intel core i7 2670qm @2.20GHz
Ram - 4gb DDR3 at 1600MHz
Hard Drive - Toshiba 700GB at 7200RPM
and i dont know what SSD i should get i was told to get Samsung 840 Pro Series 256GB 2.5IN SATA3 Mdx Solid State Disk Flash Drive SSD
Link ---> http://us.ncix.com/products/?sku=77219&vpn=MZ-7PD256BW&manufacture=Samsung%20Memory%20%26%20Storage
but i dont know can anyone help? thanks :D
https://linustechtips.com/topic/12079-i-need-help-with-finding-a-fast-ssd/
Way I would do is open your laptop up, disconnect your drive and get out wi a ruler and measure your clearance. I daresay you've got room for a 7mm drive but double check.
For the SSD itself, Samsung 840's are pretty good. Only go the pro if you need faster write times. Otherwise Plextor M5's, Intel 335's, OCZ Vector, Crucial M4..
That SSD seems absolutely fine. Suitable for your laptop.
On an unrelated note, Price:Performance of your laptop is bad.
Ryzen 5 1500x, Noctua NH-L9x65 SE-AM4, GA-AB350N, 16GB 1600Mhz, EVGA GTX 970, 250GB Samsung 960 Evo, 120GB Samsung 840 Evo, 1TB WD Green & 2TB Seagate Barracuda. 650w OCZ ZX & Cooler Master Elite 130. Acer CB241HQK 4K, LG IPS234V-PN 1080p, Ducky Zero Shine All Blue/Anne Pro Brown/SteelSeries Apex Pro & Razer Naga 2014
