I used to use a computer (got a new one) that was actually pretty good with games and video editing, even though i used integrated graphics. But, ever since a couple years ago, when I would restart, it would (the majority of the time) send no signal to a monitor. Every monitor I tried would do the same thing. I tried a graphics card and it did it almost every time. But, if i turn it off and wait like 15 minutes or so, it would be fine. I don't know if it's an easy fix, or if it's a huge problem. Any help would be good.
SPECS:
Foxconn 2AB1 Motherboard
AMD Phenom II X4 960T
2 8GB DDR3 Ram sticks running in Dual Channel
Windows XP SP2 x64 (happened on other OSs)
https://linustechtips.com/topic/1207630-no-signal/
What psu do you have ? And how old is it ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1207630-no-signal/#findComment-13704154
