Media Server (PLEX) and NAS / Problems / help
Go to solution Solved by Jarsky,
8 minutes ago, MrSimplicity said:
C:\Windows\system32>telnet localhost 21
220-FileZilla Server 0.9.60 beta
220-written by Tim Kosse (tim.kosse@filezilla-project.org)
220 Please visit https://filezilla-project.org/
C:\Windows\system32>netstat -ano | findstr ":21"
  TCP    0.0.0.0:21             0.0.0.0:0              LISTENING       11732
  TCP    [::]:21                [::]:0                 LISTENING       11732
  TCP    [::1]:52191            [::1]:21               TIME_WAIT       0
C:\WINDOWS\system32>telnet 192.168.1.39 21
Connecting To 192.168.1.39...Could not open connection to the host, on port 21: Connect failed
So if I'm not dumb as kind of know what I'm looking at. The server is running and working and my PC just doesn't connect. either that on I have failed to configure something and i have no idea what.
Yup so what the netstat tells us is that port 21 (Default FTP Port) is listening.
The local telnet tells us that youre able to connect to the FTP server on that port.
The remote telnet, tells us that connection to that port is blocked. aka a Firewall.
So assuming you're using the built in Windows Defender Firewall, you could try disabling  it for testing purposes
If that works its a matter of configuring your firewall rule. You can add it by making Filezilla Server an allowed app
Okay so yesterday i had a post up on what parts to get to build a server and i never really got responses so i took what i already had and headed to microcenter and got the rest. So now i have a system as follows:
MB: Asrock B365 Pro4
CPU: 8700K
RAM: 32 GB Gskill 3200Mhz 16x2
Storage: 256gb nvme ssd
              8TB Seagate Barracuda
              8TB Seagate External Drive (that i had previously that has been hosting all of my movies and shows)
PSU: Corsair 750 watt
GPU: 980Ti (cuz why not)
OS: Windows 10 Pro (will change if necessary, not familiar with linux bases OS' or FreeNAS but am willing to convert)
Now for what i'm deal with: It took me a bit to get network file sharing to work, was a lot easier back on windows 7, but eventually did. Then was running into issues with administrator privileges on TeamViewer so i eventually realized to use Remote Desktop being that it's already built into windows. Though after i got Remote Desktop all setup with multiple users to have access to their own files on the NAS, I no longer can access the shared folders on the network. This isn't really an issue as I'd rather take a more technical approach to that anyways. So i scoured the Internet on how to setup a Local FTP Server. No matter what i did i just can not get it to work. I tried the FTP Service built into windows and did everything and more that all the tutorials said to do. Then i decided maybe there's a program out there to make this easier and found FileZilla's FTP Server but couldn't for the life of me get that to work either.
I like having the option to just use Remote Desktop as i'm familiar with it since i use it at work. Being that i also use it as my source of acquiring said movies and shows instead of my gaming PC. So is there a way that i can get my network accessible shared folders back or more preferably someone to help me get FTP to work.
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
https://linustechtips.com/topic/1207382-media-server-plex-and-nas-problems-help/
Sharing is the same in Windows 7 vs Windows 10.
-Check your connection is using the appropriate network profile (e.g Private)
-In Network & Internet Settings > Sharing Options - Turn on Network Discovery and the File & Printer Sharing
-Right click the Folder/Drive you want to share > Properties > Sharing > Share
Add the local user accounts you want to access the share, and their permission level.
If you want everyone to be able to access it, then the user is 'Everyone'
What did you change? Why do you need to give users RDP if you're mapping a share?
SMB/CIFS (Windows File Sharing) isnt a less "technical" approach to FTP, its a different use case.
If you don't need to edit/access files "live" then yeah FTP works, but for editing documents, watching/listening to media files, etc.....FTP is horrible, as you have to transfer the entire file locally. You also have to reupload the entire file to update it on the server.
IIS FTP is horrible to work with if you don't work with IIS. FileZilla Server is a good one.
Free TFTP from SolarWinds is really good as well as a free alternative.
What trouble are you having with FTP? What errors are you getting when you try to connect using a client?
SMB would be the best way of working with media like this at home, since you can direct stream it with media players (VLC,mpv,mpc,etc....) and attach it to things like Kodi, Plex, etc....
Need more info  on what you've troubleshooted though, and what you're experiencing.
Do you see the shared folders if you go to \\<servername>  in your File Explorer?
What happens when you try click on a share?
If you open Computer Management on the Server and go to "System Tools > Shared Folders > Shares" - what do you see?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
My god i'm dumb i was so focused on everything else and RDP and a FTP i forgot about that... So that works again.
Well I was just fucking around with it and I like the way RDP works. I was trying to run things as admin (i.e. CMD and Powershell) and in teamviewer the screen goes black unless you babysit the server and for me that's in a different part of the house. Also I'm basically the only one that will be using RDP so it's not really an issue as far as anything goes really. I also plan on run games servers off of it too at times, probably won't be a 24/7 use case cuz my roommate gets bored of games and moves on quickly. So a server doesn't last more than maybe a few days.
I've done almost everything... Port forwarding, managing every port in firewall, even trying to just fully open it to the internet (which i do eventually want to do if i get requests for movies that someone wants to watch while I'm at work). Everytime I try to connect it just says connection timed out and could not connect. The main reason i want to use FTP over basic file sharing is because I like the interface better. For me it just seems more fluid when i comes to file transfers. FileZilla's GUI is better for me than just having 2 file explorer windows next to each other.
So after i made sure both the server and my PC were both on "private" i can access the folders again. Before it still showed up but it just said i didn't have access to it even after messing with permissions for hours.
So the case really is that other than occasionally running a game server and using RDP to download the movies and shows directly on the server, i don't want to be just downloading random files and such on the server. It doesn't bother me risking my main PC cuz I only game on it, if something happens i can always just start over with windows. I want to be able to avoid that at all costs with the server. So my plan is to use my PC to test programs or download plugins and such then transfer them to the server. Also actually using it as a NAS to backup my PC. I don't really think i'm explaining it all that well but I like the way FTP works and it's always felt faster to navigate than the network folders.
Also what is SMB and the benefits of it?
Mic: Blue Yeti
Yeah the black screen is a known thing caused by UAC (User Account Control). I just RDP personally for managing servers. TeamViewer should generally be used more as a support tool. You can disable UAC, but its not advised generally from a security perspective.
OK so connection timed out.....is this from your PC on the local network, to the server?
Can you open Command Prompt, and run the below command and advise the output
telnet <server name/ip> 21
Also open Command Prompt on the server, and run the below 2 commands and advise the output
telnet localhost 21
Sounds like you may have enabled filesharing on only the Private network, and not on Public/Guest.....In Network & Sharing Center > Advanced sharing settings...if you look you'll actually see drop downs for each of the different profiles. Private, Guest or Public, Domain, and All Networks. If you go into the Guest or Public, and enable file sharing in there then it should stop your server from being inaccessible if it ever happens again.
SMB or CIFS, is the Windows File Sharing protocol, its what File Explorer uses for navigating your network share, and what allows you to just simply click on a video file and play it locally without copying the entire file to your computer. Or be able to edit a document without copying it, editing it, reuploading it.
telnet localhost 21
So it says telnet is not recognized as a command on either CMD or PS, I ran both as admin as well... I ran a ping though and it pinged fine until it came to the port, I think that's due to i basically reset everything and unistalled the FTP servers and undid the port forwards. So i am back at square one. When i get or find better instructions I'd rather start from the beginning.
and yes this was on my main PC which is on the same LAN as the server
as far as that goes i did in fact have filesharing turned on for all 3 on both computers.
Mic: Blue Yeti
You can install telnet client through "Turn Windows Features on or off"
Telnet is used for testing TCP connectivity, in particular to check if certain ports are reachable.
But yeah if you have no service running on that port since you uninstalled Filezilla, then it will just time out, or connection refused.
I'll get it all back up and running and try that.
Mic: Blue Yeti
telnet localhost 21
So if I'm not dumb and kind of know what I'm looking at. The server is running and working and my PC just doesn't connect. either that or I have failed to configure something and i have no idea what.
Mic: Blue Yeti
@Jarsky Well you're a f*cking life saver. So that works, now if you're up for it, could you help me get it to work over WAN as well. Sometimes i download things on my phone while im at work and while working 10-12 shifts I'd like to get things uploaded to my media server promptly.
I think though it's working cuz the console entries match up but i can't seem to browse the file system or upload.
Mic: Blue Yeti
to get it to work over WAN theres just the 2 things
- You need to have a dedicated IP address from your ISP, not shared (e.g CGNAT...its most commonly used for mobile broadband)
- Forward the port in your router configuration
You can use whatever port you want externally, you could just try port 21, and forward it to 192.168.1.39  Port 21.
You can find instructions for your router on https://portforward.com
Keep in mind most ISP's give you a dynamic IP address, so you either need to request a Static IP address, or use a DynDNS service such as DuckDNS so you always have a way to reach it.
Thank you so much. I'll look into that and see what i can come up with. If i can't get it, it won't be the end of the world.
Mic: Blue Yeti
