Dual Channel Ram Help
Go to solution Solved by Fasauceome,
Just now, johnno124 said:
i currently have 2x8GB sticks installed and i need to increase my ram capacity,
Your memory will operate with two sticks per channel, so you will have dual channel still.
im looking at getting a second pair of RAM for my PC, i have checked to make sure the timings and speed are the same (i am getting another kit of the exact same model ram), I was just looking and The Ryzen 5 2600X can only support Dual Channel, Does that mean i can't add 2 sticks or is that not what dual channel means.
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
https://linustechtips.com/topic/1207132-dual-channel-ram-help/
Dual channel means two ram sticks can be addressed at the same time, so you ideally want something like 2x8GB of ram.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1207132-dual-channel-ram-help/#findComment-13700285
For an explanation of "dual channel", just try a google search.  I did and got this in response.  Be advised it is a long read.
https://www.crucial.com/articles/about-memory/what-is-dual-channel-memory#:~:text=Dual-channel RAM is one version,memory and the memory controller.
https://linustechtips.com/topic/1207132-dual-channel-ram-help/#findComment-13700294
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
https://linustechtips.com/topic/1207132-dual-channel-ram-help/#findComment-13700298
Primary PC:
PSU tier list
https://linustechtips.com/topic/1207132-dual-channel-ram-help/#findComment-13700305
ok so adding 2 more sticks just increases the capacity but stays in dual channel as opposed to quad channel. Thanks'
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
https://linustechtips.com/topic/1207132-dual-channel-ram-help/#findComment-13700307
Yes, as I'm sure you guessed only expensive CPUs get quad channel, like threadripper and such. It requires a more expensive motherboard and memory controller.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1207132-dual-channel-ram-help/#findComment-13700310
