2 minutes ago, Ben!?555 said:
So I was wondering if you had a monitor that runs 60hz on 3840x2160, would you be able to run more hz if you lowered the resolution to 1920x1080?
The panel won't change it'll still run at 60 hz no matter what you do.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1206867-help/#findComment-13698076
