Hi there, thanks for clicking on this post. We want to design, make and maybe sell wooden computer cases with our school project, but we need some user input to make sure we are including the right features and make the right design choices. It would be very appreciated if you could take one or two minutes and fill in this short survey. Thanks in advace!
https://docs.google.com/forms/d/e/1FAIpQLScpO5RYJeMVdf_r5uVeHaww4lh36hyCPMR2VPR8eBfNuHmITA/viewform?usp=sf_link
https://linustechtips.com/topic/1206515-help-wooden-pc-case/
I didn't answer the survey because I find the questions weren't that great.
Pretty much every question in there is subject to ones personal opinions. I think if you're designing a custom case you're best off going mid tower as that's pretty much the most common platform, but literally everything else is personal opinions and statistically will vary significantly. If it's something you truly care about you should design the perfect case for you, and what you want. That's the magic of custom work. It's unique. Then if that's a success and you want to make options (i.e. wood choices, different designs/sizes/mounting options, etc) then that's your prerogative.
I personally would never buy a wood case, purely because I feel that they lock me into a very specific style niche that you're sort of forced to follow. But I've still seen some wood concepts/designs and think they look unique, clean, and flawless.
Also are those photos on the survey your work? Or just filler photos?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1206515-help-wooden-pc-case/#findComment-13695284
