Hello,
Firstly I do not know where to post this, and this seemed like the best option. So please forgive me for that. Secondly, as far as I know the LTT Forum doesn't have much regarding virtualization but I'm running out of options and this forum has never failed me before.
So,
I'm running a MacOS Sierra VM on a Windows 10 host on VMware on an ryzen 2600. I am running it on a previous version of VMware because 15.5 doesn't work well with ryzen and MacOS. Everything is running fine and stable but I can get vmware tools to download, it's grayed out. I don't have it downloaded but the options shows as update vmware tool and its grayed out.
I looked it up online and it said to remove CD Drive from the hard ware options and add it again and select physical drive option or something along those lines. I tried that but I am still struggling. Does anyone have any idea or any suggestions? Please?
Thank you so much!
https://linustechtips.com/topic/1206399-vmware-help-please/
you can't macOS on Windows. Might be a problem
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1206399-vmware-help-please/#findComment-13694167
4 minutes ago, Jas99 said:
The VM is running perfectly stable on windows and i even have ICloud working. I do not understand what you are saying
violates EULA
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1206399-vmware-help-please/#findComment-13694197
12 hours ago, wall03 said:
violates EULA
That doesn't mean it wouldn't work. Current forum policy is to allow discussion of Hackintosh and such as long as disc images, downloads etc. aren't shared. So if you don't have anything to contribute in way of helping, and don't approve this discussion, just skip it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1206399-vmware-help-please/#findComment-13696266
