the pre-applied paste isnt bad, but MX-4 is a top tier so you will likely gain a marginal benefit from swapping it, maybe in the 1-3c range.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1206005-included-wraith-cooler/#findComment-13690627
