Budget (including currency):  $400 USD
Country: United States
Games, programs or workloads that it will be used for: Pro Tools, Lightworks, Light Gaming such as Minecraft or Civilization 6, Lots of video streaming (Youtube, Twitch, Netflix, Hulu, etc)
I already have monitors, keyboard, mouse and headsets. I've been watching Linus for a long time and decided I would take a shot at building my own pc after dreaming of it for a while. I am also looking for a decent sound card too but I have no idea where to start the search for that. Any help is appreciated. This PC needs to be super low budget though. Any way to substitute parts for other parts that will give the same benefit but cost lower is much appreciated.
AMD    Ryzen 3 3200G    $99
CPU Cooler:    AMD    Wraith Stealth Boxed Cooler    Included
Motherboard:    ASRock B450M PRO4 AM4 AMD    $84
Memory:    Corsair    Vengeance LPX 16GB (2x 8GB) DDR4-3200 CL16    $63
Storage:    ADATA    SU635 256GB SSD    $36
Case    Rosewill FBM-X2 Micro ATX Mini Tower  $40
EVGA 500W 80Plus Power Supply Unit $48
https://linustechtips.com/topic/1205817-my-first-build/
This computer will do perfectly fine with video streaming but you need to define light gaming a bit more. If you're serious at all about it you need to consider getting a dedicated graphics card. Unless you're fine with turning some games down to 720p or something.
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13688981
The build you picked out is very servicable and probably does what you want. If you really want to go that rout, i'd highly recommend you go for a ryzen 5 3400G instead, it has a better GPU and more threads.
But I'd recommend you try to get a cheap used system. like a dell optiplex or something similar. Linus did a video on that recently.
If you get something like a i7 3770 or 4770 you'll have the same CPU performance as the ryzen 3 3200G/3400g (well they are a bit faster, but not substantially),
and then get a dedicated GPU for the system, as well as a new SSD.
The SSD does not use a DRAM chache (they use them to index your drive. It basically holds a map, that tells the drive, where it has to look for your data) and it uses QLC NAND (each cell of the SSD can hold up to 4 bits of data. Generally the more bits it holds, the slower and less durable they become).
I'd recommend you get the ADATA SU760, which cost $34.99. It uses TLC (3 bits per cell) and has a DRAM buffer.
Actually it does not have a DRAM cache, sorry for missinforming ... On the official website it states: With SLC Caching and DRAM Cache Buffer.
But the DRAM Cache Buffer is apparently the internal SRAM of the controler, not an actual dram cache ... I would get whatever cheap SSD with DRAM cache you can get. The crucial MX 500 is a good buy, but a bit more expensive.
If you have any other questions, fell free to ask 🙂
Edited by adm0n
Wrong information
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13689002
How would this work? Ill try and find the Linus vid on it but how much upgradeablity and compatibility does a pre built like a optiplex have?
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13689053
Usually it just has a pcie x16 slot for a GPU and if you are lucky some x1/x4 slots. You might be able to swap the CPU, but you have to make sure, that you stay within the range of the cooling system, which is usually not easily swappable.
RAM and storage works like everywhere else als well, you'll just have some ram slots and some sata ports.
This should be the video I mentioned (I really hate those titles ...):
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13689061
From what I understand going that route might not save much more than 100 bucks on parts with also trying to find a usable old system so wouldn't it be better to build from the ground up?
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13689191
The PC they showed in the ebay listing was $130 with an i7 3770 and 16GB of Ram. so you'd only need a SSD as well as a GPU.
Compared to your build, with a decent GPU, it could be like 4 times as fast and you have like $200 to spend on a GPU as well.
Unless I did my math wrong ._.
The thing with building a PC new at that price point, is that you are not really in the sweet spot for price to performance, so everything kinda feels like a waste of money.
If you really would want to build a new PC, I'd buy a ryzen 5 3600 for $166, which gives you enough power for gaming as well as productivity task. But now you also need a graphics card. Maybe like a RX 580 or something similar, which will also run you another $170.
With that you have a competent machine, but it is quite a bit more expensive.
I think the current virus situation made the used market a bit more expensive, than it should be, but even then. If you look at this PC:
https://www.ebay.com/itm/Dell-Optiplex-9020-Intel-Core-i7-4770-3-40GHz-16GB-RAM-500GB-HDD-DVDRW/233581873760?hash=item3662908a60:g:siAAAOSweKRetKSl
You get a comparable CPU to your configuration, as well as the ram and so on in one package.
Then you throw in this GPU for $160 (for example): https://www.amazon.com/Gigabyte-GeForce-Graphics-Compact-GV-N1656OC-4GD/dp/B086TSK5M3/ref=sr_1_2?dchild=1&keywords=GTX+1650+OC+4G&qid=1591523012&sr=8-2
and some SSD with a dram cache. Linus found a 128GB one for I think under $30. The one i recommended in my last post, didn't have one. I corrected that. sorry.
You will still spend like ~$50 more but you suddenly can play most games in 1080p at 60fps, while before your pc would have struggled at 720p ...
If you really want to build a PC from the ground up, that won't be a server (because those ryzen chips are awesome for that), I'd recommend saving and spending a bit more. It will last you a lot longer that way and you'll have a decent experience. Your current conifg will probably be bad at what you want it to do fairly soon.
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13689246
@Sticks5803 - I have been waiting for this moment. Here's a really good $400 build!
It's a lot faster than the build you picked out.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13689575
10 minutes ago, Sticks5803 said:
Is a video card/gpu necessary for that build? Im not gonna be running a whole of high demand games so is it really worth it to spend the $130 for that?
If this is going to be primarily a video editing PC, then I would build this, with the recommendation to add another SSD when you can. This is a significantly faster CPU, twice the SSD space to store projects, but a much, much worse GPU. It'll reduce your gaming performance markedly, but it should help with video editing quite a bit.
https://linustechtips.com/topic/1205817-my-first-build/#findComment-13690881
