I've been recently getting frame spikes in games and I have no idea why. Im using a 2060 super and a ryzen 7 3700x, aorus x570 elite, gskill trident z neo 3600. I dont think I should be getting lag spikes and Im trying to figure out why. Any tips or suggestions?
https://linustechtips.com/topic/1205355-frame-spikes/
Frame spikes ?
Like do you mean it rises alot for a second and then drops ?
Or frame dropes ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13685133
6 minutes ago, Nickolass said:
For example fortnite, sea of thieves. There both stored on a wd blue 500 gb ssd and all low settings.
Is the game locking up and stuttering or are you seeing FPS dips?
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13688407
23 minutes ago, Nickolass said:
Both
If it's locking up, that typically points to drive issues. The game can't pull resources off the drive in time to process.
Is the drive almost full? Does it have errors?
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13688504
2 hours ago, Nickolass said:
Yeah drops.
Use ddu
Enable xmp / dcop
Check temps
Update the bios
Build Log:
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13688692
I put sea of theives on my c drive and its a wd blue 500 gb ssd. It has like 200 gb left on it
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13696549
5 minutes ago, Nickolass said:
Ive done all that
What are your temps ?
Build Log:
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13696560
1 minute ago, Nickolass said:
At most Ive hit is like 75 on my gpu my cpu is never above 55
Check if you have xmp/ dcop on
Build Log:
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13696566
For my ram?
Yes lol
Build Log:
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13696571
Just now, Nickolass said:
Yeah thats on lmao
Have you tried display driver uninstaller (ddu)
Build Log:
https://linustechtips.com/topic/1205355-frame-spikes/#findComment-13696574
