So, I got a new build this week:
R5 3600X
ASRock b450m steel legend
Corsair 16GB RGB 3200mhz
Sapphire RX 580 8gb
Cooler Master SILENCIO S400
Corsair CXM 550 W 80+ Bronze
I've installed everything correctly and it won't post. The motherboard RGB lights up when powered, but Everytime I turn the system on, the cpu fan spins briefly and stops. I tried every trick that I know of, even techniques used in the 2000s, but it's not posting at all. Is it something in the bios? And I stupid? Is there an issue with the wattage? In any case, I'm stumped.
https://linustechtips.com/topic/1205281-new-build-will-not-post/
Probably just have to return/exchange the motherboard.
it might not actually have the updated bios it needs.
only thing I can think of. Assuming the DDR4 isn't just slightly loose or something, or some other connector.
The mobo is fine, only thing I haven't done is update the bios. But that by itself I have no clue of doing. Ram is sitting perfectly as well.
You would need to borrow a CPU that can make the motherboard boot to check the bios yourself.
How would I go about doing that?
You can try to get an AMD boot kit, or maybe a local PC shop will have a spare ryzen CPU lying around.
