By "ISP routers", do you mean modems with routing functions (i.e. internet gateways)? If they are, they don't tend to allow access to all necessary options to activate/deactivate for this to occur.
But let's try. What are the makes/models of the devices?
Can your wireless devices get a good signal in the shed?
10 metres is not far to run gigabit ethernet. Why can't you do this?
https://linustechtips.com/topic/1205249-wireless-bridge/#findComment-13684619
Hey, falcon1986
I ended up getting a 15 meter Ethernet cord and wired it out to the other router/ modem and creating an uplink from the modem combo unit in my house to the other modem combo unit in my shed. The only problem I can see is that the 2 IP addresses could cancel each other out
https://linustechtips.com/topic/1205249-wireless-bridge/#findComment-13692154
Hey, falcon1986
https://linustechtips.com/topic/1205249-wireless-bridge/#findComment-13692159
You have to put the second router in bridge mode or basically disable features that allow it to run as a simple switch.
https://linustechtips.com/topic/1205249-wireless-bridge/#findComment-13693415
