Pc overheating Issues
Go to solution Solved by Lauris Roze,
Ive found the fix for the issue, for gaming, i used the gpu power to use less power from cpu making the game playable and shutdowns non-existing.
I feel like that isnt the problem cause neather the gpu or cpu overheated, it was a whole diffrent think, it was the remote and i dont know where its at. And the remote is the only think thats passing 75°C and gets me to 90°C witch shuts down pc.
https://linustechtips.com/topic/1204922-pc-overheating-issues/#findComment-13681984
From looking back at some old articles, the max safe temp for Athlon 64 X2 CPUs was around 65C, yours is already showing 68C in that screen grab. Change your CPU thermal paste and unclog and clean any heatsinks and fans then see if it is still doing the same..
https://linustechtips.com/topic/1204922-pc-overheating-issues/#findComment-13682015
5 minutes ago, Lauris Roze said:
The only issue is that this isnt my own pc, but its only pc over here and i dont hawe my own pc yet.
ask the owner to change the thermal paste.
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
https://linustechtips.com/topic/1204922-pc-overheating-issues/#findComment-13682025
