Budget (GBP 😞 £1500-2000
Country: United Kingdom
Games, programs or workloads that it will be used for: Mainly used for gaming and some college work and just every day task
I already have these parts :
CPU : RYZEN 7 3700X
GPU: EVGA RTX 2070 SUPER
RAM: VENGENCE PRO 16GB
Case: Lian Li O11 dynamic
Motherboard : ? need help choosing
Stoarage: ??
Cooler: ??
PSU: ??
https://linustechtips.com/topic/1204757-need-help-building-new-pc/
Does the budget include the parts you already have?
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
For a motherboard, imo the best motherboard would be the Asus Rog Strix X470-F.
I would obviously recommend an SSD so like maybe a Samsung 970 Evo Plus - a nice nvme SSD. For a cooler I'm not really sure, depends if you want to water cool your system or not, if not than any good choice of fans in a well placed configuration will be just fine, water cooling is nice though. I'm not the most knowledgable on cooling though, so double check with someone else or some YT tutorial before purchasing any random fan.
what about x570
@Maurya123For a motherboard i would recommend staying away from the ASUS range, i have an ASUS RoG Crosshair Hero VII Wifi and paid £250 for it and its the worst unstable board i have ever owned even with the newest bios it randomly resets ram settings even though the ram is listed in its recommended and supported part on the site.
I would recommend MSI for motherboard
A Nice Samsung 970 EVO Plus like listed above and for cooling .......
An AIO like the corsair h115i.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
Yes thank you i was thinking of getting the Asus range motherboards but now i will stay away from them thanks for letting me know
2 minutes ago, Maurya123 said:
Yes the budget includes the parts that i already have
If possible then, what's the remaining budget then? I don't know how much you spent on the stuff you already got.
here's a general list of what I would go with
mobo:something x570 with good power phase (power delivery design) but if you don't know what that means don't ask me because I don't either
storage: 1tb nvme pcie gen 4 ssd, 2-3tb hard drive
cooler:h115i for liquid or nh d15 for air
psu: 800 watt 80 + gold fully modular supply from a brand you know like corsair or evga
CPU : RYZEN 7 3700X
Stoarage: ??
Cooler: ??
PSU: ??
PCPartPicker Part List: https://uk.pcpartpicker.com/list/MH7nBZ
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  (£74.98 @ Amazon UK)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  (£195.97 @ Laptops Direct)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  (£101.98 @ Amazon UK)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£121.40 @ Alza)
Total: £494.33
Generated by PCPartPicker 2020-06-05 12:19 BST+0100
heres a Mobo, cooler , storage and psu. probably fit some extra storage in there if you want to.
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
Total: £494.33
That cooler won't fit.
oh in that case go with a aio. didn't see the case size 😅
