Any background processes running?
Temps? is something overheating?
Use MSI afterburner + rtss to see if something is overheating or if something is being underused
To be perfectly honest, 160FPS sounds about right for a stock 3570K in CS:GO.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
With weaker settings and in this mode, FPS must be much bigger
played with I7 2600, with same configuration --had much better performance about 230-260 fps
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-2600-vs-Intel-Core-i5-3570K/620vs1316
The 2600 is a 4C/8T part, whereas the 3570K is a 4C/4T. The slightly better IPC of Ivy Bridge won't make up for the lack of hyper-threading, particularly since you're running it at stock speeds.
Also, generally, regardless of settings you'll still be CPU bound in CS:GO.
