Need Help Upgrading GPU
Go to solution Solved by Jurrunio,
Yes it will bottleneck
and if you care about RTX performance, waiting for 30 series make more sense.
So I've had my current GPU (GTX 960) for well over 3 years now
and I am thinking of upgrading to RTX
So I was searching on NewEgg the other day and I found this RTX 2080S
https://www.newegg.com/gigabyte-geforce-rtx-2080-super-gv-n208saorus-8gc/p/N82E16814932175
I have an i7-6700 with 16GB @2133 MHz
My monitor is 1080p 60Hz but I am upgrading to a 1440p 144Hz in the near future
So I want to ask if my current CPU will bottleneck the GPU
*planning to upgrade to Ryzen*
https://linustechtips.com/topic/1204383-need-help-upgrading-gpu/
Desktop benching:
That i7 6700 (or should I say the equivalent to a modern i3 10300) with the slow 16GB DDR4 2133 isn't able to feed an RTX 2080 type of a card.
I would not pair it with a card stronger than an RTX 2070. To be frank, it's great for RX 5600XT, 5700 and GTX 1660S, 1660Ti or RTX 2060/2060S.
If you plan to upgrade the platform soon, get the strongest card you can, but if you'll wait a few years to upgrade the CPU - then get an 5600XT, 5700 or RTX 2060.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
No I am actually planning on upgrading monitor and CPU to Ryzen within a few months so I guess that's what you mean?
If you absolutely need the more cores and threads like today I suppose you can upgrade
But if you can wait
Getting something like a zen 3 ryzen 5 with it's improved ipc and imc and potentially a big improvement to the interconnect and waiting for ampere , then that will be well worth the wait
Phone: Pixel 3a (Purple-ish).
Build Log:
Then get the strongest card you can. Or wait for RTX 3000 or AMD big Navi.
Don't overthink the "i7" bottleneck, it will limit the performance (but still playable) till you upgrade to Ryzen 4000.
