Witch desktop would you choose. Should i go with AMD or Intel.
Yes I know that you can build your own for cheaper. I have a $3,000 budget on the desktop
Looking at this one, anything i need to change/customize let me know. https://www.ibuypower.com/Store/AMD-Creator-Daily-Deal
https://www.ibuypower.com/Store/Mothers-Day-Sale-AMD-Ryzen-9
https://www.ibuypower.com/Store/AMD-Creator-Pro
https://linustechtips.com/topic/1203373-pre-built-ibuypower/
2 minutes ago, JayR said:
Witch desktop would you choose. Yes I know that you can build your own for cheaper.
Prebuilts? Two ways to go. Boutique and upgradable or non upgradable.  Non-upgradable might as well go full Monty and get one of those SFF systems.   CorsairONE kind of thing.
Boutique upgradable I don’t know.  Lot of choices. IBuyPower had a funky rep after that cooler fiasco.  Not sure if iBuyPower falls into upgradable or non-upgradable.
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669119
that thing should do literally anything you throw at it, although the ram is a bit slow imo. you are spending a lot more money to get it pre-built, but if your fine with that, then go for it.
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669129
Can you explain how the ram is slow it says ddr4 32gb
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669144
Asus tuff gaming x570 is rated tier E on the motherboard tierlist.  You can fit a 3950 in it but it won’t power it reliably.  Also 3000mhz memory?
this is looking like a bad idea.
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669149
It says ddr4 32gb 3000mhz. Ddr4 is what kind, 32gb is how much (a fairly large amount) 3000mhz is how fast.  3200 is reasonable if not quick, 3600mhz is recommended for ryzen2
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669160
would 16gb of ddr4 4000 be better than 32gb of 3200?
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669167
No, because 4000 is too fast.  There’s this weird thing about the ryzen2 infinity fabric: if it goes above 3733mhz it runs at half speed.
32 of 3200 will be slower than 16gb of 3600 for anything that uses less that 16gb (which is every game ever) but faster for things that use more (like workstation stuff) kinda depends on what you are doing.
the aorus elite WiFi is a little more money but a much better board.  It will actually handle that 3950 without choking.
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669190
Operating System :: Windows 10 Home - (64-bit)
Case :: iBUYPOWER CB007 Aluminum
iBUYPOWER Elite Build Package :: None
Case Fans :: Default Case Fan
Case Lighting :: None
iBUYPOWER Labs - Noise Reduction :: None
iBUYPOWER Labs - Internal Expansion :: None
Processor :: AMD Ryzen 9 3950X Processor (16x 3.5GHZ/64MB L3 Cache)
Processor Cooling :: iBUYPOWER 240mm Addressable RGB Liquid Cooling System - Black
Memory :: 32 GB [8 GB X4] DDR4-3600 Memory Module - Certified Major Brand Gaming Memory
Video Card :: NVIDIA GeForce RTX 2080 Ti - 11GB GDDR6 (VR-Ready) - Single Card
SLI Bridge :: None
Motherboard :: MSI MPG X570 GAMING PRO CARBON WIFI -- RGB, 802.11ax WiFi 6, ARGB Header (2), USB 3.2 (6 Rear, 2 Front)
Power Supply :: 800 Watt - High Power - 80 PLUS Gold (White Cables)
Advanced Cabling Options :: Professional Wiring - for all standard default cables inside the system
Primary Hard Drive :: 1 TB WD BLUE SSD + 2 TB 7200RPM Hard Drive
Secondary Hard Drive :: None
External Optical Drive :: None
Media Card Reader / Writer :: None
Sound Card :: 3D Premium Surround Sound Onboard
Network Card :: Onboard LAN Network (Gb or 10/100)
USB Expansion Card :: None
i changed the ram to 3600 32gb
also switched out the motherboard
Price $3380.00
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669193
Memory :: 32 GB [16 GB x2] DDR4-3000 Memory Module - Certified Major Brand Gaming Memory
SLI Bridge :: None
MSI mpg isn’t on the tierlist. I don’t know.  Here’s a link to the tierlist for what it’s worth
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669201
SLI Bridge :: None
Price $3380.00
Do you think the water cooling sytem and fans are up to par
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669207
It has this card on it by default
Should i change it out for this for a extra $40?
Intel Pro 10/100/1000 Gigabit Ethernet Network Card
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669214
I just call it the Carbon, MEG MAG are both human names, MPG is for fuel consumption. Stop this stupid ****, MSI
Not the carbon... it just cant compete with boards from Asus or Gigabyte.
Cooler and fans are acceptable, just dont overclock the CPU cores.
No. The 1000 Gigabit rating is wrong, it should be 1000 Megabit which is 1 Gigabit. So does the one for onboard, 10 megabit, 100 megabit or 1 gigabit.
Honestly you should only get faster LAN card when your network switch is also up there and you have something to connect that fast to (say a NAS or internet data plan).
Desktop benching:
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669230
i only get 100mb/s worth the lan card?
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669236
1000mb/s. Just like the onboard one (on the X570 carbon)
Desktop benching:
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669241
SLI Bridge :: None
Price $3380.00
Ouch.  I’m not real worried about the AIO. 240mm AIO is more or less 240mm AIO more money is mostly about less noise with those and while 140mm is probably not enough, 240 is more than enough.  Big air might also be an option but it’s not offered.  So lower end 240 AIO should be fine.  The kraken will be a bit quieter but it’s more money.
im a hair worried about the PSU. 800w and 80+gold are nice and all but they don’t say whether the PSU is actually any good or not. PSU stuff is all about component safety.  If a PSU goes it can wreck your whole system. I’ll throw the PSU tierlist at you while I’m at it.
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669250
Thanks i'll give it a look
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669363
Can you explain what the AIO is and the PSU
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669398
AIO stands for All In One. It’s a liquid closed loop cpu cooler with pump Rez and radiator in a single sealed unit.
PSU stands for Power Supply Unit.  It’s the box with cables that turns wall ac into a couple different voltages of extremely even DC.  It’s got big capacitors and stuff in it and is the most physically dangerous part of the machine.  Because it supplies power to everything if it blows up (they can actually blow up or catch fire unlike the rest of the machine) it can send enough voltage to fry any component in the machine.  A good one resists doing that and has redundant protections so hat if it does fail it won’t hurt the rest of the machine when it does.   A cheap one doesn’t so it’s both more likely to fail and will do more damage if it does.
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669434
Heres my build. Ill go with the PSU that i have and upgrade it down the road. If anything goes wrong with the PC i have a year warranty ill have my psu upgraded by then.
Case :: be quiet! Pure Base 600 Tempered Glass Gaming Case - Black
Case Lighting :: iBUYPOWER RGB Lighting
Processor Cooling :: iBUYPOWER 360mm Addressable RGB Liquid Cooling System - Black
SLI Bridge :: None
Motherboard :: GIGABYTE X570 AORUS ELITE WIFI -- RGB, 802.11 ac WiFi, ARGB Header (2), USB 3.2 (6 Rear ,2 Front)
Primary Hard Drive :: 1 TB WD BLUE SSD + 2 TB 7200RPM Hard Drive - Single Drive
Secondary Hard Drive :: None - Single Drive
https://linustechtips.com/topic/1203373-pre-built-ibuypower/#findComment-13669510
