stability problem
i have a stability problem with my pc. when i start 3DMark (Time Spy) the pc keeps crashing. the screen goes black on all screens. I don't use overclocks at the moment. I did use overclocks but they were all light. I updated all drivers. my temperatures are all fine during a stress test on my ryzen 2700x i get 49c. with an overclock of 4.3 ghz all core 64c. gpu wise i use a 5700 XT from asus ROG strix. the temps of the gpu are fine (even if that is not always the case with the 5700xt from asus ROG strix). does anyone know a solution to this problem. the big problem is crashing and sometimes a bleu screen.
System specs:
CPU AMD Ryzen 7 2700X
RAM Gskill F4-3600C18D-16GTZN
GPU Asus ROG Strix RX 5700XT 8GB
Motherboard Asus x470 prime
powersupply Corsair rm850
CPU Cooler Arctic liquid freezer ii 360mm
disk C WD Blue SN550 NVMe SSD
Extra Disks WD bleu 1tb HDD
                   WD Green 3tb HDD
                   WD bleu 1tb HDD
                   WD Bleu 500G SSD
At the moment I don't even have my RAM at it's rated clockspeed.(running 2133)
I also have to note that i have a lot of monitoring and benchmark programs installed. i have MSI Afterburner and ASUS GPU tweak II.
Sorry for my poor english. I'm from the Netherland
https://linustechtips.com/topic/1203188-stability-problems-with-pc-please-help/
Try to minimize the amount of reporting/performance software you have installed/running at one time. They can interfere with each other and cause issues (from what I understand, they're all trying to communicate directly and they can't distinguish which software sent which requests for information and they confuse themselves).
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
1 hour ago, timonpaco said:
stability problem
Going Black, is either:
a) The GPU has crashed (eg the video driver)
or
b) The CPU/MB has shut down the video card for some other reason. This is why you need to listen to the audio to see if it's locked up.
Make sure to install the chipset drivers, which is something people tend to forget when they build a new system. The chipset drivers traditionally were enabling the high performance features of the GPU, USB, Power management, and so forth. So if you forget them, then the OS tends to fail a lot when you start tweaking things.
  • 6 months later...
or
Thanks for the advice,
Even tho its along time ago. I did a reinstall for my chipset drivers and the problem was solved.
Tanks :)
