1 minute ago, gloop said:
I can count at least 2 fan headers so you don't need a splitter/controller.
Yes but OP needs DC fans and not pwm
I could be wrong but I don't remember seeing DC connectors on that board
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1202688-fan-compatibility/#findComment-13663479
1 minute ago, Cloaked said:
@gloop are you 100% sure? I’m pretty sure there’s a CPU fan header and one sysfan header
That would make two headers. Do you need a third?
If so, a fan splitter will be fine. I've used multiple splitters on really cheap motherboards.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1202688-fan-compatibility/#findComment-13663498
Just now, Cloaked said:
I need two sysfan headers, yes.
In which case, any cheap splitter will do.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1202688-fan-compatibility/#findComment-13663502
Although, there does seem to be two fan headers aside from the CPU fan. One above the PCIe x16 slot and one at the bottom of the motherboard
Edit: ninja'd
Primary PC:
PSU tier list
https://linustechtips.com/topic/1202688-fan-compatibility/#findComment-13663509
Oh yeah, I see them now. And 3-pin fans can work with those headers, right?
Theoretically speaking yes
The 4th pin isn't actually used for power
Build Log:
https://linustechtips.com/topic/1202688-fan-compatibility/#findComment-13663519
