3 minutes ago, LOST TALE said:
These things age right?
I think something yellow melted on those spring looking things.
It's 8 years old now.
While PSU's do age, It depends on the quality of the unit. High end PSU's tend to come with a 10 year warranty. I'll be replacing my 12 year old OCZ unit (Which will remain as a testing PSU) with a newer Seasonic Focus PX when it comes in.
The yellow melted stuff comes from the factory, to protect the inductors (The round coiled objects) from vibration.
If it's a cheap PSU, 8 years is a contender for replacement. If it's a high quality unit, you may have time left, yet.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
Pretty sure it's always been there.  Surprised it took you 8 years to notice.  😉
It's RTV.  Nothing more.
Yes.  Of course.  But it depends on the PSU.
I can tell you have an Antec.  Which one?
oups I thought I had it in my signature. HCG620M
My first guess would be to wait until the system starts crashing when stuff is at stock. However, if it crashes rarely enough, I would lower my overclocks for nothing, thinking its my gpu or something thats aging.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
Eight year old double forward,group regulated PSU.  I'd go ahead and replace it.
What's that? does it matter which of the 4 8pin power plugs I use?
On any half decent PSU the thing that will age the most is the fan.
Electrolytic caps do age as well but tends to be the lower tier manufacturers and/or lower rated series that go earlier. Even see that in fairly bulletproof linear supplies every so often.
