Hi Everyone, I am having trouble with my GTX 1060 6gb and is causing many problems. First off, it starts to flicker in game during loading screens and frame rate is not smooth with gsync when it hits under 90 fps. Any help would be greatly appreciated and also the time I bought this graphics card it was used probably should have gone with a new one. Second, gsync does not start up for the first time when I turn on my PC, generally I have to restart it again to get gsync to work. I'm currently saving to buy a new GTX 1080 to play games at high settings with 144+ FPS if possible
My rig
i7 6700K @4.5 GHZ
GTX 1060 6gb GIGABYTE
16 GB RAM
1 TB HDD
120 GB SSD
EVGA Bronze 750 Watt PSU
I got a brand new monitor which is the ACER Predator XB241H, clearly could not be the problem
https://linustechtips.com/topic/1202403-gpu-problem-with-pc-games/
try dduing the drivers
Phone: Pixel 3a (Purple-ish).
Build Log:
1 minute ago, Alps240 said:
I have done it last week and it did not work
do you have any sort of over clock on your gpu ?
Build Log:
No not at all
oh well is this monitor gsync compatible or does it have the module ?
Build Log:
Im guessig it is the GPU?
cant really know
was this gpu flashed before buying it from the seller ?
did he say something about that ?
Build Log:
16 minutes ago, Alps240 said:
No not at all
You will have to DDU and try older drivers. If you are trying to use a Freesync monitor with G-sync, a lot of the flickering issues have to do with your GPU and driver compatibility. You will notice it will come and go with driver updates and every driver update I have seen, has someone complaining "my g sync not working and flickering". Those who are unlucky have to roll back to previous drivers and try again when the next drivers roll out.
EDIT: But you have a G sync monitor so I am confused why this issue is happening lol. I thought it only happens to use freesync monitor users.
2 minutes ago, pedram_vi said:
change your hdmi.
1st welcome to the forums
2nd what ? How would that help ?
If the cable was the problem then it wouldn't just happen in games and other problems would occure other ths stutters
Build Log:
