Okay so I have a 5700xt that has been flashed with the wrong vbios. With it installed I get vga post code error on my ryzen build. My question is; if I install it in an Intel build would it likely post on integrated graphics? To reflash the cards vbios.
Thanks in advance
aBowlaPuddin
https://linustechtips.com/topic/1202248-vga-error-post-code/
Try using something with an apu like an Intel bench or a ryzen apu
See if its defected and try flashing it
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1202248-vga-error-post-code/#findComment-13660104
Okay, so I've tried the card in an Intel PC. When into bios, changed default video output to onboard. Powered down, installed card, rebooted. No post. Remove card reboot to bios and it had defaulted output to pcie again.
Board is a ASRock z170m (friends PC, don't know much else)
https://linustechtips.com/topic/1202248-vga-error-post-code/#findComment-13660822
Try clearing the cmos
Try updating the bios
Build Log:
https://linustechtips.com/topic/1202248-vga-error-post-code/#findComment-13660828
