Hi,
I want to upgarde my system to Gigabyte Z390 Aorus Elite Motherboard with Core i5 9600 k Processor and Zotac RTX 2060 Amp Card,so i am previosuly using Cooler master thunder 600W SMPS so it my Power Supply is enough for this Specs,Please suggest moreover i dont want to spend another bucks in buying smps.
https://linustechtips.com/topic/1202203-system-upgradation/
1 hour ago, Charlie Groves said:
I did a rough power calculation and the 600w should be fine but make sure you have the right connectors image.png.21133889a567c30fd9dafab69560b0f4.png
No that is not correct
A 500w or a 550 should be WAYY more than enough
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1202203-system-upgradation/#findComment-13659965
I agree that a 500w would be fine but a 650w allows for upgrade ability and overclocking on CPU and GPU, extra storage, more fans ect...
CPU: i7 6700
GPU: GTX 1060 6GB
RAM: 16GB DDR4 2133 MHZ
Storage: 2TB Crucial SATA SSD + 2TB WD BLUE
https://linustechtips.com/topic/1202203-system-upgradation/#findComment-13659997
A 500w should be enough for even a 3700x and a 2070 super
Build Log:
https://linustechtips.com/topic/1202203-system-upgradation/#findComment-13660000
A 3700x and 2070 SUPER on their own with no OC is 365W and OC could push that to 400W and then you have all of the rest of the components.
Just saying that I like to play it safe in terms of power supplys and buy a bit more than you need. You future self will thank you and having that extra headroom is useful
CPU: i7 6700
GPU: GTX 1060 6GB
https://linustechtips.com/topic/1202203-system-upgradation/#findComment-13660012
Future proofing is not Necessarily wise since you end up making a system that is so "future proof" you won't have any budget for a specific part or two that could enhance the experience
If you worry about future proofing so much you will end up building a jank of a pc
I don't recommend future proofing
Care about your current rig not what it will look like in a few years or so
Build Log:
https://linustechtips.com/topic/1202203-system-upgradation/#findComment-13660019
Fair enough. Just different ways of doing it I guess
CPU: i7 6700
GPU: GTX 1060 6GB
https://linustechtips.com/topic/1202203-system-upgradation/#findComment-13660035
